First time poster here that wanted to share a problem to help others. I've contacted tormach support and hopefully they solve it. I'll post the resolution once I get it. Or, feel free to comment if you've ever seen this before.
Details of problem:
Any X+ or X- axis milling sounds terrible. As soon as the machine switches to the Y- or Y+ movement the sound goes away. video here
https://www.youtube.com/watch?v=_Jzf4R2tSIg
The video is a block of 6061 aluminum being milled by a 1/2 4 flute HSS end mill. It's at 3600 RPM, 30 IPM, .3 DOC, .1 stepover.
The video is just an example, this problem remains across the following tests:
1. tried a 3/8 or 1/4 end mill
2. lowered/raised RPM
3. lowered/raised IPM
4. changed stock to 1018 steel
5. choked up tool in collet for less stickout
6. 2 vs 4 flute, HSS vs carbide
none of the above make any difference. the only way i can get X to not sequel is to do something ridiculously slow like a .03 DOC on a 3/8 end mill.
