I've got a .dxf with 2500 circles in it. Their diameter ranges from 1.75mm to 4.4mm.
What is the best way to make simple holes according to those diameters?
- creating a drilling path will mean that I need a drillbit specific to each hole diameter, which I don't have...
- creating a pocket path for all of them with a 1mm bit, means a really long calculation time (about 30min) and then an estimated milling time of 27 hours!!
- is the smartest way to divide them into groups and create a pocket path for each group so that I can a different bit for each diameter group (meaning one group with a 1mm bit for the 1.75 holes, then another group with a 2mm bit for the larger holes for example)... ?
I hope my question is clear.
Thanks.
