585,667 active members*
4,038 visitors online*
    Apr 2010
    Z axis laser machine
    Hi guys,
    I am about to start designing a CO2 laser cutting/engraving machine (size +- 2,5x1,5 meters), but before I can start I have a question regarding the Z axis of a laser machine.
    I see many people constructing a complete movable bed as a Z axis which can go up and down. My question is: isn't it easier to make a Z-construction for the Lens? So the lens could move up and down (closer and further away from the material)? Or is there another reason behind the fact that people are using the bed as a Z-axis and not the lens?
    Nov 2015
    371
    Re: Z axis laser machine
    It would depend on the purpose of the Z axis. The dynamic focus heads are typically used for cutting sheets that are not perfectly flat. The adjustable bed is used for setting the focal distance before the cutting/engraving operation.
    Nov 2008
    644
    You could adjust the lens up and down. That adjustment is limited but probably well within the thickness variation you can cut. Engraving thick materials is another story. If you don’t have macro Z adjustment you need to have an alternate way to remove the bed so you can clean it.
    I would like to make a CNC Laser with these measurements. The problem is that not much knowledge and I look for a tutorial (DIY), to be able to guide me.
  1. Calibrating X and Y axis on 4060 China laser engraving/cutting machine.
    By doken in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-17-2021, 09:31 AM
  2. Shakes on the Y axis in 6040 CO2 laser machine
    By snopa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-24-2018, 10:35 AM
  3. Calibrating X and Y axis on 5030 China laser engraving/cutting machine
    By raipe in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-22-2016, 01:31 PM
  4. Replies: 0
    Last Post: 03-06-2014, 05:37 AM
