585,898 active members*
4,751 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Emco PC turn 55 burned inverter is the 8200 compatible?
    Aug 2010
    30
    Hello, I recently acquired a PC turn 55 lathe. While plugging it in at home I heard a loud pop. Looked inside the machine and the inverter had some burn. Uninstalled and took apart to find a non labeled discrete resistor burned out. I found a similar replacement but I do not know if it is compatible. The model number of the one I found is e82ev751_2b200. The picture is of my original
    Dec 2013
    5717
    Re: Emco PC turn 55 burned inverter is the 8200 compatible?
    I think the .2B200 means 200 volt class. I say yes, it looks to be compatible.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2010
    30
    Thanks Jim. I'm going to go ahead with the purchase. They dont accept returns so if it is not compatible I will try to sell it.
    If anyone else wants to chime in its appreciated.
    Aug 2010
    30
    Found a matching model number that was affordable. I installed and will try to power up for functionality.
  1. Replies: 2
    Last Post: 02-23-2018, 03:35 PM
  2. emco turn 120p with emco tronic ti control
    By rcjacob in forum Vertical Mill, Lathe Project Log
    Last Post: 03-26-2014, 05:01 PM
  3. Emco PC turn 120
    By spankyky in forum EMCO CNC Machines
    Last Post: 06-26-2010, 02:09 AM
  4. Emco Turn 320
    By J_Copeland in forum Want To Buy...Need help!
    Last Post: 10-21-2008, 05:26 PM
