Hi Folks!
I'm working on a project to revive a Mori Seiki MV Junior VMC with a Fanuc 10M Controller for quite a while now..
Great progress has been made, as the machine (axes) and controller are now working almost entirerly. :banana:
One problem stillt troubles me:
When Im in MDI mode und try to run the spindle, just for testing (without tool) with:
S1000 M03;
then the spindle turns ON, but it turns only very slow! The movement also seems a bit irregular and not smooth.
That means around 4 RPM or so. If I command an other RPM, the speed does not seem to adjust.
If I turn the spindle off again and try to spin it by hand, it turns freely without any problems.
The machine does not report any alarm or problem whatsoever.
Previously, I have been resetting the machine completly, meaning entering all parameters, Options, Timers, Keeprelays by hand.
Can this spindle behavior be the result of a wrong parameter?
Thanks for any advice!
