585,973 active members*
4,101 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Vectric Aspire V3 post processor menu
Results 1 to 6 of 6
    Dec 2018
    11
    Hi All
    I see that most posts say that one should first select the post processor from the drop down menu. However I cannot see any drop down menu in Aspire at all. Does anyone know where to select from? I need to select Mach3
    Kind Regards
    Nov 2004
    89
    Re: Vectric Aspire V3 post processor menu
    Not sure if Aspire 3 is the same as the current versions. When you save your tool paths there is a option to select for post. Expand this and select the Mach 2 post.
    Ed
    Apr 2005
    304
    When you click on icon for saving toolpath, you will have the opportunity to select post. See attached picture.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Dec 2018
    11
    Hi
    Thank you for the reply. But nowhere can I see this menu. here are two pics of the open Aspire3.
    You need to open the toolpath tab in the upper right corner, create toolpaths, and save them. It's while saving the toolpaths that you'll see the post processor list..
    Dec 2018
    11
    Thank you Ger21. Sometimes little things get overlooked! Only realized the toolpath menu in the top right hand corner
  1. Vectric or ArtCam 2018 (Post Processor)
    By VictorAntipoff in forum Post Processors
    Last Post: 11-06-2017, 04:17 PM
  2. Post Processor Aspire
    By hebert franco in forum Aspire
    Last Post: 10-31-2016, 03:44 PM
  3. Larken 24/24 CNC Post for Vectric Aspire?
    By crob09 in forum Larken
    Last Post: 07-21-2016, 01:48 AM
  4. Bridgeport R2#4 BOSS 9 Post Processor for Aspire (Vectric)
    By bevins in forum Bridgeport / Hardinge Mills
    Last Post: 05-15-2013, 04:11 PM
  5. post processor?? vectric
    By redvanth in forum Chinese Machines
    Last Post: 08-21-2011, 05:15 AM
