I have a cnc 6040 Chinese 4-axis-rotary-one of the drivers that goes in a rack does not work, it's the driver because I change the position and the axis does not work where it is.
A second red LED lights up, even if the motor is not connected.
I guess it has no solution, I have been researching and there is no way to buy a driver is Shindiao.
I will have to buy a new driver mach3, 4 axes, but I have doubts about the power the engines are nema23 but there is one.
57HS10042A4, of 4.2 A.
What driver would you advise?
Thank you
