585,996 active members*
4,005 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Newbie question - How can a palette hole be made?
Results 1 to 12 of 12
    Dec 2018
    24
    The hole is shown in this page https://www.benjaminsalley.com/inthe...-palettes.html
    I appreciate your help.
    May 2015
    1422
    Re: Newbie question - How can a palette hole be made?
    If the angle of the hole's walls is the same for the whole circumference, mount the palette on an angle jig so the walls are vertical then come in with a pocket, contour or even boring operation.
    If the angle is changing or your machine won't support the Z height needed to clear the palette on the angle, look at mounting it flat on a jig that incorporates a spoil board, rough out with a straight cutter and then put the angled faces on using a spherical ball mill aka lollipop cutter.
    Dec 2018
    24
    Quote Originally Posted by dharmic View Post
    Thanks for your answer. I think the angle is not the same for the whole circumference, right?
    Are the methods you described CNC, or manual machining?
    Cut the elliptical hole on the CNC, then wrap sandpaper around a dowel, and sand in the angle by hand.
    Dec 2018
    24
    Thanks. It is better to machine the angle than make it by hand, right? What is the name of the angled surface?
    Aug 2014
    232
    Use a "lollipop" cutter.
    May 2015
    1422
    By sanding's a great idea if there's only one or a few to do. If you're belting out hundreds then I'd be trying to automate it.
    I'm thinking those techniques would work for either manual or CNC, the only difference is it's tough doing an ellipse on a manual table.
    You'd probably need a really long tool to CNC the angle.
    A better option than hand sanding would be a spindle sander with an angled table. It would only take a few seconds each, if you were making a lot of them.
    Dec 2018
    24
    Quote Originally Posted by Zorbit View Post
    I will look into that. Thanks
    Dec 2018
    24
    I want to make a large quantity and sell them, and looking into the method and cost of doing that. Thanks
    Dec 2018
    24
    OK, thanks for the info. I will look into the spindle sander.
    Dec 2018
    24
    Okay, I will look into that, Thanks
  1. moving hole made using hole wizard SW2011
    By themotorman in forum Solidworks
    Last Post: 11-16-2014, 05:51 PM
  2. how are thru hole coolant holes made?
    By yoshi900 in forum CNC Tooling
    Last Post: 08-26-2012, 07:50 AM
  3. Newbie's hole question
    By eaglezsoar in forum MetalWork Discussion
    Last Post: 12-08-2010, 10:40 PM
  4. Can the HF 8X12 be made to have a 1" thru hole
    By sunnyday in forum Mini Lathe
    Last Post: 10-04-2009, 05:24 PM
  5. Replies: 9
    Last Post: 02-11-2008, 05:54 PM
