585,949 active members*
4,083 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 5C spindle modification for Tormach mill ?
Results 1 to 15 of 15
    Oct 2014
    97
    I am getting back to my Tormach 1100 and am still interested in the idea of a 5C spindle for the main spindle. I cant seem to find anything on this, wonder if anyone ever went ahead with this type of project ?
    Dave Lawrence
    Apr 2013
    1788
    Re: 5C spindle modification for Tormach mill ?
    The OD of a 5C collet is almost 1.25 but an R8 is only about 0.95 (see R8 and 5C Collet Dimensions | Metal Arts Press). What is the ID of the lower bearing in the spindle?
    Sep 2009
    624
    Quote Originally Posted by kstrauss View Post
    1.565" more or less. So you've got about a 0.15 wall, vs a 0.3 wall. Might get interesting.
    Apr 2013
    1788
    Quote Originally Posted by GLCarlson View Post
    You considerably over-estimate the wall thickness without replacing the bearings since a 5C collet uses a drawtube rather than the drawbar of R8.
    I'm curious though. Why would you want 5C?
    Nov 2013
    402
    My thoughts exactly.
    Why would you rather have 5C instead of R8?
    Mar 2009
    1863
    When I got my 1100 in July of 2011, the first thing I did was put a 3/4 inch HARDINGE R8 collet in it. I have never changed that collet and even after thousands of hours, I can put a 3/4 inch dowel pin in the spindle and when I put an indicator on that dowel pin it looks like the indicator is stuck.
    The collet that came with the machine was good, but the HARDINGE is better.
    AND, a 5C collet has external threads while an R8 has internal threads.
    Mar 2013
    344
    Steve, I'm convinced and will order a new Hardinge, but doesn't Tormach's have some unique feature that allows it to work with the TTS system?
    Nov 2012
    591
    The main unique part of TTS is an R8 3/4" collet with a flat (rather than rounded) bottom face.
    The flat face means that it fits inside the turned groove on the top shoulder of the TTS holder itself, so the ground reference face of the shoulder clamps straight against the bottom of the spindle.
    Oct 2014
    97
    My motive for a 5C spindle is for using the machine as a vertical lathe. I have an ongoing job of creating quantitys of a gearblanks ...its just under .750 diam, I am doing it on a manual turret lathe , using a Warner Swasey M1372 roller box tool I can easily hold close od all day long. Would like to start making these on the tormach , and dont want to give up the roller box...think its a little large to hang up there for going to a rapid turn. So I could plug off 3 blanks per load as is, since this is a yearly run of 3500 , seems like a spindle modification that would allow a longer rawstock slug might be worth building. Not looking at 5c for increased diameter at this point , just increased depth. I think a spring loaded bar puller would work if I had some length up in there to pull.
    Thanks Dave
    Feb 2006
    7063
    Buy something like this:
    https://www.ebay.com/itm/5C-Collet-C...alq4:rk:7:pf:0
    Make an adaptor to attach it to the existing R8 spindle. You'll likely need to make it fully adjustable (both concentricity and co-linearity) to get acceptable runout, given how long it will be.
    You can also get small R-8 shank 3-jaw chucks. Use one of those, and use a grinder to true up the contact faces on the jaws.
    Regards,
    Ray L.
    Mar 2009
    1863
    Quote Originally Posted by jwatte View Post
    I used mine just the way it came out of the box.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Mar 2009
    1863
    Quote Originally Posted by DLawrence View Post
    Thanks Dave
    I use a TTS ER-32 collet holder for turning.
    Apr 2013
    1788
    Are the blanks just under or just over 3/4-inch (R8 collets are available in diameters of up to 1-inch in increments of 1/32-inch)? How long is each blank?
    Jul 2004
    1424
    So why don't you just chuck them up in a 3/4" R-8 collet? Assuming your raw stock is 3/4" in diameter? Or a 7/8" R-8 collet with slightly larger stock?
    Or if they are undersized enough that the R-8 collet won't grip them, try to see if there is a metric R-8 collet that works better.
    Failing that, get an R-8 emergency collet blank and cut it to the exact size you want.
    https://www.shars.com/r8-emergency-collet
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Nov 2012
    591
    I think he wants to use the spindle as a semi-chucking collet. I e, he wants to hold, say, 12" of stock, turning out a 2" piece, moving it down 2", turning out another piece, ...
    The longer you can make the stock when you start, the less you waste in "holding area" for that last stump you can't really machine.
    I think an actual lathe is probably a better option ... What with buying new tooling as well as the cost for a spindle change, getting a mini/small/cheap CNC lathe might be doable. (Something like mini-lathe + stepper motor conversion, or Shopmaster lathe.) Of course, those options won't be as rigid as the Tormach, so the details of the work matter.
  1. Replies: 7
    Last Post: 03-06-2015, 01:41 AM
  2. Post Modification for Mill-Turn
    By lenny09 in forum BobCad-Cam
    Last Post: 10-19-2014, 06:02 PM
  3. Spindle Key Modification
    By cnckid in forum Uncategorised MetalWorking Machines
    Last Post: 08-06-2012, 10:02 PM
  4. SX3 Spindle Modification
    By Old Megawatts in forum Syil Products
    Last Post: 05-31-2010, 08:49 PM
  5. BP Spindle speed control modification
    By Jerry7 in forum Bridgeport / Hardinge Mills
    Last Post: 08-14-2008, 06:53 PM
