585,715 active members*
3,743 visitors online*
    Jul 2003
    123
    dip switch settings for 5056 stepper driver
    hello
    I Need to set the
    dip switch settings
    for the 3 KL-8056 Drivers
    https://www.automationtechnologiesin...rivers/kl5056/
    (KL23H2100-50-4B)
    X,Y motors
    https://www.automationtechnologiesin...lat-570-oz-in/
    and
    KL34H280-55-4A
    For Z
    https://www.automationtechnologiesin...-640-oz-in-55/
    pin 4 off for x,y on full current for Z
    direct drive PM-25 Mill
    2nd build
    Jul 2003
    123
    Re: dip switch settings for 5056 stepper driver
    Franco explanation
    https://www.youtube.com/watch?v=5D7px0r0pUE
    Quote Originally Posted by sidecar82 View Post
    hello
    I Need to set the
    dip switch settings
    (KL23H2100-50-4B)
    X,Y motors
    and
    KL34H280-55-4A
    For Z
    2nd build
    Jul 2003
    123
    got machine PM-25 cnc conversion moving
    switches
    DO NOT FLIP SWITCHES UNDER POWER
    U will Blow the drive
    No Smoke 2 ?
    set step switches
    5,6,7,&8
    to--- off,off,on,on
    8th step
    stepper motor 20 steps per revolution 1.8 DEG = 200 steps.
    So that 1600 steps per rev
    I thought the ball screws were in inches they are not
    they are metric
    I MDI command X 7 inches machine moves to 6.889 measured
    Display shows 7.0000
    machine moved measured 175 mm=6.889
    stepper motor made 35 turns
    SO to calculate of a metric screw
    turns per inch for a metric ball screw
    7 inches =7*25.4=177.8 mm
    177.8/35=5.08
    so 5.08 = number of turns of the ball screw to
    get inch inch of movement
    hope this help some one ?
    machine now moves the correct distance
    YES 7 inches
    8th step plenty of Power no stall
    forgottoturnonspindlemotor
    end mill pushed part out of vise ?
    still attempting to mill
    been using MDI
    switch 4 set to off (off makes power reduction to on ?)
    123
    for X,Y on off on
    for Z on,off,off
    motors have been on for over a hour and are cool, not even warm!
    and had Power to move
    No Smoke 2 ?
    OK that all for now
    Mar 2018
    13
    Thanks for sharing. I'm starting a build to convert a Seig X2D to CNC. When I get to assembly I'll definitely be looking at the relevant formulas.
    My original plan was to convert a little machine shop 3990 mill to cnc so I bought the cnc mechanics and electronics at the same time. My problem is that I like having a manual mill in the shop. I decided instead to buy the Seig for CNC.
    I am interested in where you got the abs case? I've been looking and the closest I found is a metal cabinet used to make electrical connections. If I go that route I'll need to make sure to isolate everything from the case. I also like the aircraft connectors which would mean drilling fairly large holes in the metal case. The plastic case would eliminate those two problems.
  1. Correct Stepper Motor Driver Board Switch Settings
    By jmsiefer in forum Stepper Motors / Drives
    Last Post: 01-27-2014, 05:25 AM
  2. Stepper Driver Settings (Microstep and Current)
    By maximusalto in forum Stepper Motors / Drives
    Last Post: 03-09-2013, 04:59 AM
  3. Stepper driver dip switch configuration
    By canadamaxxer in forum Syil Products
    Last Post: 03-24-2010, 04:50 AM
  4. Stepper driver settings 1/8 vs 1/2
    By BubbaGump in forum Australia, New Zealand Club House
    Last Post: 11-17-2009, 11:46 PM
  5. Keling 5056 Driver Error HELP
    By Cartierusm in forum Automation Technology Products
    Last Post: 12-20-2007, 04:54 AM
