585,971 active members*
4,211 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Anyone have experience with these linear motion slide table
    Mar 2017
    116
    Anyone have experience with these linear motion slide tables?
    I have some questions about this;
    1) can the ball screw be removed if replacement required?
    2) are the aluminium frames weak?
    15362
    Re: Anyone have experience with these linear motion slide table
    Quote Originally Posted by damunk View Post
    This is used for a router Z axes which are only used for someone's first machine build, unsupported rails are not ideal for anything like this, also the ballscrew thrust bearing setup would be suspect as well, the aluminum frame should be fine for all this would be capable of
    Mactec54
  1. Replies: 4
    Last Post: 06-15-2015, 01:20 PM
  2. T-Slot Delrin bearing slide for linear motion on DIY CNC?
    By telmnstr in forum Linear and Rotary Motion
    Last Post: 02-15-2015, 01:19 PM
  3. Replies: 14
    Last Post: 04-10-2011, 06:38 PM
  4. CNC Linear Motion Slide System
    By george_grat in forum Want To Buy...Need help!
    Last Post: 11-08-2010, 03:40 PM
  5. Linear slide table
    By NitroXide in forum Linear and Rotary Motion
    Last Post: 05-29-2007, 05:31 AM
