585,908 active members*
3,829 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > 3D milling 8mm bit issue
    Aug 2017
    31
    I am working on my first 3D milling wood piece. The 3D model is a concave fruit bowl, with multiple concave parts to it.
    I'm using a stepcraft 840 machine, with a MM-1000 spindle.
    The first settings I used were:
    8mm, 3-flute bit
    30% stepover
    Pass depth 4mm
    12000 RPM
    15mm/sec feed rate
    10mm/sec plunge rate
    machine allowance 0.5mm
    ramp plunge 5mm
    The program settings were a 'roughing pass' for the 8mm, and I also have a path for a smoothing with a 3mm bit.
    Once the job started, at first it went well, but then I noticed it was a bit jumpy as some spots, so I thought to raise the RPM.
    I raised it to 16000.
    The I thought it might be good to lower the feed rate, so I lowered it in UCCNC to 60%, which makes it 9mm/sec.
    But at this point, the bit was strangely waaaay too deep in the wood, kind of double the depth it should have been.
    Then quite quickly the whole piece jumped, I think because the wood touched the shank of the 8mm bit, because it was too deep in the thin cut it made in the wood.
    The questions are:
    1) Are the feeds and speeds I set wrong?
    2) After this fatal error, I would take out the 8mm bit from the spindle by hand.. so I think the collet is broken... how can I check and make sure if that's the case?
    3) How is it possible that the spindle went down to a Z of more than 4mm, if the pass was set to 4mm? (the first few cm of top-surface were cut to 4mm, but then it went down further without completing a first pass).
    4) There was literally a hole straight through the spot where it jumped. Only by chance it didn't go through the entire 38mm. It's not supposed to go any deeper than 20mm into the material, more or less, according to the file.
    I would really appreciate any help and insight to prevent this from happening again...
    Thanks!
    Apr 2005
    304
    Re: 3D milling 8mm bit issue
    It seemsthat you did not tighten the bit in the collet enough and it creeped out.
    Anyway, by FSWizard with rpm set to 12000 your feed should be around 25 mm/sec, and at 16000 rpm around 33 mm/sec
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Aug 2017
    31
    I used the FSwizard before setting it up, but I didn't get your results. Can you explain perhaps a bit what you put in the setup there? I put the diameter and sizes of the bit, and the material as wood, with a depth of cut at 4mm.
    What else should be there? It tells me that with 12000 rpm, the feedrate is 98mm/sec...
    Aug 2017
    31
    Followup issue:
    I tested another time with the 8mm bit, with the following settings:
    8mm bit, 3 flutes
    5.1mm pass depth
    10.2mm cut depth
    30% stepover
    12000 RPM
    15mm/sec feed rate
    This is a simple curve file with a Profile toolpath, so some of the settings don't matter.
    It started nice, but my spindle has a manual set of the RPM value, and I forgot that it's still on 25000 RPM. About 30% into the job, the depth increased, so I stopped it to see what happened. I lowered the RPM to 12000 and ran it again, but still - same issue of suddenly going deeper into the wood..
    I thought it might be again the clamping nut and collet, but it isn't, I checked and the bit is still the same and it didn't slip out.
    The wood plate was secured from the 'top' on one end, but from the 'side' on the other end, meaning I placed another piece of wood and clamped it down, to block one end from going forward, while the other end was held down by screws.
    So I think that one end was open to movement in the Z direction, and the power of the bit, regardless of the precise settings, 'pushed' up that end of the wood plate and that's what made the cut deeper.
    What do you think?
    Thanks!
  1. milling issue
    By deadlykitten in forum Okuma
    Last Post: 01-27-2016, 04:50 PM
  2. Milling issue
    By DavidhCNC in forum BobCad-Cam
    Last Post: 03-07-2015, 06:50 AM
  3. V-Groove Milling issue
    By CYoung in forum BobCad-Cam
    Last Post: 10-24-2014, 01:15 AM
  4. Hex Milling Issue
    By yz85608 in forum Mastercam
    Last Post: 04-03-2012, 03:48 PM
  5. SprutCAM 7 Milling Issue
    By Pat_IS in forum SprutCAM
    Last Post: 07-16-2010, 01:00 AM
