585,687 active members*
4,196 visitors online*
Thread: Grounding
    May 2014
    7
    Grounding
    I never bothered running a ground wire from the 220V plug, to the J1 connector on KSTEP, so it always just ran of the +/- from the transformer/capacitors, with the ground on the 220V plug cut off. Should i bother running the ground wire to the J1 from the 220V plug?
    24220
    Re: Grounding
    A system that is mains powered should always be earth grounded for safety.
    You should also use it for any motor frame grounding and enclosures etc.
    See NFPA79 for a reference.
    Al.
    Albert E.
    Dec 2019
    Well, the main system should be grounded in terms of safety and in terms of good accessibility as well. On the other hand, I am glad to see that your followers take part in the conversation actively. I need help with assignment that would be really great if you provide.
  1. UC100 and Win10 Home
    By Bad Wolf in forum UCCNC Control Software
    Last Post: 12-23-2018, 02:50 AM
  2. v21 on win10 keeps crashing
    By rccars4sal in forum BobCad-Cam
    Last Post: 08-21-2017, 02:49 PM
  3. Jcut USB Drivers???? Win7 Win8 Win10
    By randomando in forum Chinese Machines
    Last Post: 07-25-2016, 07:05 PM
