585,974 active members*
4,359 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Error Message on startup
    Feb 2007
    68
    Has anyone seen this during startup? Last 2 times I turned on the machine this came on. Turning it off and on makes it start up fine. Not sure why the error? This machine spends most of it's time turned off and has very few hours of cutting time on it.
    1206181438 by JAMES ANDERSON, on Flickr
    RH19plate by JAMES ANDERSON, on Flickr
    Jul 2010
    548
    Re: Error Message on startup
    Hi gunmaker, Error 187 is saying that the NCB board and the interface panel has lost communication.
    1st thing to check is the 5VDC power supply and check / set to 5.2VDC. if the 5V falls to 4.999999999V it will drop the communications. that is why it should be set to 5.2V.
    There are other possible problems, bad NCB board, interface problem. but lets check the easy stuff 1st.
    Give me a call 952-288-6340
    sportybob
    Feb 2007
    68
    Thanks Bob. I'll get back to you after this weekend. Gotta maintain my kids car to get him back to college.
    James
  1. Crazy HAAS Message at Startup
    By teacherjon in forum DNC Problems and Solutions
    Last Post: 08-29-2015, 04:18 PM
  2. Startup error
    By Dennis K in forum CamSoft Products
    Last Post: 08-29-2014, 10:56 PM
  3. MPC6515 stuck on startup message
    By indrora in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-21-2014, 02:47 PM
  4. Vm-20 getting error 449 at startup
    By Elmss12 in forum Milltronics
    Last Post: 03-07-2014, 06:06 AM
  5. Error on Startup
    By JerryFlyGuy in forum Phase Converters
    Last Post: 06-28-2007, 03:22 AM
