585,575 active members*
4,014 visitors online*
    Dec 2018
    Acorn relay board
    I have a couple questions ...one does acorn activate the relay on the relay board in the case of a e stop ..the wiring diagram for acorn to dyn4 shows the relay for estop but it shows it normally open to the contactor was just wondering how thats going to work ...another question is the meanwell 24 volt power supply big enough to supply power to the contactor and another contactor for my router plus power up acorn and all those relays or am i going to need a bigger power supply the one i have is rated for 1 amp its the one for 24volt and 5volt
    Mar 2008
    1762
    Re: Acorn relay board
    A good number of the relay configurations will DEactivate when an estop event is detected. You can use an output configured as "OkFaultOut". It will activate once the software boots up and deactivate when reset or estop is activated.
    Most small relays will pull <50mA, contactors~100. Total them up and try to keep them under 500mA. You can test with a voltmeter. Measure power supply voltage with nothing other than Acorn connected, then connect the rest and see if the voltage drops more than a few tenths of a volt
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
  1. How to use relay on break out board
    By Curran in forum CNC Machine Related Electronics
    Last Post: 06-11-2018, 12:54 PM
  2. Mini Mill Running Acorn Board and Software
    By AMHKnives in forum Centroid CNC Control Products
    Last Post: 08-09-2017, 12:54 AM
  3. relay board question.
    By dasf in forum CNC Machine Related Electronics
    Last Post: 10-30-2014, 10:09 PM
  4. Relay Board
    By Darc in forum Controller Cards
    Last Post: 11-03-2010, 09:23 PM
  5. Relay for HobbyCNC board
    By pilotjunky in forum Hobbycnc (Products)
    Last Post: 12-24-2008, 07:50 PM
