584,863 active members*
4,709 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Y axis limit switch not detecting or it detects at zero
    Aug 2017
    112
    Hi all ,
    I am using Kflop Board , in that board i am connecting pin IO 0 AND IO 6 to my limit switch for y axis. IO0 for positive and IO1 for negative.
    When i am trying to move y axis from 0 to positive it detects the limit switch and stops the axis.
    similarly from 0 to negative direction it is detecting and stopping the axis. That it is supposed to do.
    But when i am trying to move from +10 to 0 it only detects when it reached 0 whether it detects limit or not it reaches to 0 and stops.
    Similarly if am moving y axis from -10 to 0 it only detects when it reaches 0 before that whether it detects limit or not it reaches to 0 and stops and detects limit at 0.
    It only happening in y axis as axis channel generator 1, all other axis and their limits are working fine.
    Please solve my issue.
    Waiting for your kind reply
    Regards
    Amit Kumar
    May 2006
    4043
    Re: Y axis limit switch not detecting or it detects at zero
    Hi Amit,
    Check if your Soft Limits are set correctly. Post your Initialization file.
    TK
    http://dynomotion.com
  1. Reposition Z-Axis limit switch?
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 01-23-2014, 03:25 AM
  2. Cant move axis off of limit switch.
    By chess7272 in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2014, 06:45 AM
  3. VF-0 Z Axis Won't Home to Limit Switch - Help!
    By roofis27 in forum Haas Mills
    Last Post: 11-18-2013, 10:55 PM
  4. Detecting TSC switch=ON
    By broby in forum Okuma
    Last Post: 04-11-2009, 02:32 PM
  5. Y axis limit switch
    By raytor in forum Benchtop Machines
    Last Post: 10-10-2006, 02:48 PM
