584,829 active members*
4,985 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 1996 4020ht - new to me, much maintenance required
Page 3 of 3 123
Results 41 to 54 of 54
  1. #41
    Jan 2010
    321
    Quote Originally Posted by triumph406 View Post
    There's somebody in Aus who rebuilds spindles, he goes by 'Machtool', maybe here, and certainly on other forums. He's mentioned Fadal spindles in the past, so I believe he's rebuilt them.
    Thanks.
    Have sent a message so will wait for a reply
  2. #42
    Jan 2010
    321
    Re: 1996 4020ht - new to me, much maintenance required
    Got onto machtool. He is too busy to look at it.
    Still trying to weigh up doing it myself
    About $800aud for the bearings they are a common spindle set here In Aus so no lead time for parts.
    I also changed out the y axis 7304 thrust bearings with proper 61deg contact angle preloaded ball screw support bearings.
    Previous i was chasing 0.01mm in the bearings and they were new. Swapped them out, no shims needed as they have 350kg or so preload on them once assembled. Now have zero backlash on that axis from the bearings and probably last a heap longer as they are a higher capacity bearing for ball screws.
  3. #43
    Mar 2019
    12
    Quote Originally Posted by Deano7/11 View Post
    Is this a kit? or did you just find these bearings for some other ball screw?
  4. #44
    Jan 2010
    321
    Not a kit just worked it out myself.
    22 years in the bearing game helped as suppliers of this bearing set a pretty hard to find.
    If it was 25mm inside dia I would have many manufactures to choose from.
  5. #45
    Jan 2010
    29
    Quote Originally Posted by rwskinner View Post
    3 of SKF Seals 12360 (Inside block coolant seals)
    1 of SKF Seal 11138 (Seal for thrust retainer to screw seal adapter)
    2 of NSK Angular Contact Bearings 7304BYGUG2 - NB5F 20mm x 52mm x 15mm
    1 of preload shim 0.875" ID x 1.375" OD x 0.001" thick
    Hello I have a VMC15XT, are these bearings and seals for each axis?
  6. #46
    Oct 2008
    1632
    Quote Originally Posted by roberto123 View Post
    These are per axis. Mine were for a 4020.
  7. #47
    Apr 2014
    344
    There were only two seals on my vmc15xt.
    The other seals are for the cool power system. Now I don’t remember what the number were for the ones I needed. But it’s one of the two above.
  8. #48
    Oct 2008
    1632
    Yep, I have (Had) water cooled ball screws, so there is an IN and an OUT port in the screw, which means 3 seals for the cooling, and 1 dust seal for the bearing.
  9. #49
    Jan 2010
    321
    Bit of an update.
    I replaced x and y ball screws seals and thrust bearings. All were changed over to proper ball screw support bearings.
    1 reballed the z axis.
    I installed a reman spindle from its
    Replaced hi/low cylinders as 1 was leaking
    Replaced the crt with a lcd.
    Pulled all the keys and dials and cleaned them.
    Rebuilt the spindle chiller pump.
    Replaced a couple if leaking chiller fittings.
    Replaced the work light with a led worklight
    General clean up and return to service
  10. #50
    Jan 2009
    52
    How is it running?
  11. #51
    Jan 2010
    321
    Quote Originally Posted by gwiz View Post
    How is it running?
    Seems pretty good. Only issue is a false estop every now and then. Always when jogging or operating manually so not a huge deal just a bit frustrating.
    Here is a pic of the cleaned up control with lcd
  12. #52
    Jan 2009
    52
    Sweet
  13. #53
    Mar 2019
    12
    should throw a few pics up of the beautiful girl cleaned up now.
  14. #54
    Jan 2010
    321
    Quote Originally Posted by HalfRapid View Post
    Yeah will do.
    Attached is some of the parts I used
    Attached Thumbnails Attached Thumbnails Screenshot_20200514-073156_AliExpress.jpg   Screenshot_20191202-215255_eBay.jpg
Page 3 of 3 123
  1. topless 4020HT
    By thomasz in forum Fadal
    Last Post: 09-19-2011, 10:48 AM
  2. 4020HT metric or not?
    Last Post: 08-06-2011, 03:16 PM
  3. 4020HT - question
    By MBX5 in forum Fadal
    Last Post: 08-20-2010, 06:17 PM
  4. Help required with Mazatrol 640 Maintenance Text.
    By piper468 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-23-2009, 04:38 PM
  5. Looking for a use 4020HT with rigid tap
    By REVCAM_Bob in forum Fadal
    Last Post: 05-13-2006, 07:50 PM
