585,665 active members*
3,763 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Y axis not repeating
    Dec 2016
    Hello all. I have a fineline automation cnc router with a gecko 540 ESS warp9 smooth stepper and I finished my build however my y axis does not repeat. When cutting around a rectangle the X is fine but the Y loses about .05 per pas but not on a constant basis. I have Mach 4 set at 1735 steps per with velocity of 400 and accel of 25. My machine had linear guides and a rack and pinion. I'm lost and any help would be greatly appreciated
    Attached Thumbnails Attached Thumbnails A9A70422-FCFF-44F5-96E9-985645A567ED.jpg   0AE88D62-BBF2-4F3D-A48E-E9F69538A995.jpg
    Jan 2007
    467
    Re: Y axis not repeating
    Can you try swapping motors around so a different axis is controlling the X and Y? You will need to change your pins in Mach4 as well. I want to see if the problem stays on the Y axis or if it tracks a specific drive on the G540.
    My gut feeling is that this is a problem with either too aggressive of an acceleration profile or too high of a speed for the given power supply voltage. What is your power supply's voltage and current rating?
    Marcus Freimanis
    www.geckodrive.com
