585,992 active members*
5,600 visitors online*
    Nov 2013
    8
    Industrial Table Build
    Hi All,
    This forum has helped me build my table so I thought I would share my pictures of the finished machine on here,
    Nov 2013
    8
    Re: Industrial Table Build
    More Pictures
    Dec 2013
    5717
    Nice Job ! :cheers:
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2018
    Nice build and solid sheds too! What profiling speeds is the table capable of?
    I have just gone away from cutting over water due to the mess, constantly contaminated linear guides and surface rust on plate if not cleaned immediately and it really didn't reduce the plasma smoke being produced from large cutting batches. I built a large overhead fume hood which helped a lot for catching 95% of the plasma smoke that goes more or less straight up whilst cutting.
    Nov 2013
    8
    Thanks for that Mate,
    The max speed I have had it run at was cutting 0.5mm black mild steel sheet at 4330mm/min, It did not have any problems at those speeds.
    Before I had finished the guards on the machine and I was using it a fair bit, I went through several linear guide blocks that got contaminated with plasma dust and water.
    Now I have installed double dust seals and scrapers as well as covering the guide blocks the best I could.
    If I do continue to have problems I would consider building a hood like yours for it, Only downside I see is if I want to move the machine in the future.
  1. Large Industrial CNC Table Routers, New to CNC
    By Royalcor in forum Commercial CNC Wood Routers
    Last Post: 11-22-2017, 08:19 PM
  2. new rotary table for its special industrial function
    By sindychen in forum News Announcements
    Last Post: 10-25-2010, 09:35 AM
  3. Industrial Hobbies Build
    By Mike Ray in forum Charter Oak Automation Support Forum
    Last Post: 01-16-2009, 03:24 PM
  4. Industrial laser table recommendations please!
    By kennected in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2007, 09:40 AM
  5. Industrial Vacuum table
    By osdhillon in forum DIY CNC Router Table Machines
    Last Post: 10-24-2005, 11:38 PM
