585,764 active members*
4,143 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > v26 how to add taper mills to planar finish in 3axis strategy??
Results 1 to 13 of 13
    Oct 2007
    446
    Question v26 how to add taper mills to planar finish in 3axis strategy??
    I want to finish planar with a taper end mill but going to the tool crib only shows endmill rough and finish as available tools....
    How can I add a tapered end mill into it???
    Oct 2012
    22
    Re: v26 how to add taper mills to planar finish in 3axis strategy??
    airbrush
    I think you have to create a new tool with manually entering parameters of the taper. I have made some tools that I had to define.
    jc
    [email protected]
    Oct 2007
    446
    Quote Originally Posted by unionoutfitt View Post
    airbrush
    jc
    [email protected]
    I only see options to set diameter length radius, but nothing for taper...maybe I'm missing something here.
    Can you walk me through it? Thx
    Oct 2012
    22
    I just looked at v31 and you can create a taper tool. Not so sure with v26. I will ask Al next time there is a webinar.
    Good luck
    jc
    Apr 2009
    3376
    No in V26 that I see
    Oct 2007
    446
    nothing in the tool that i see that allows you to set a taper...only thing that lets you set any kind of taper is in the tool and arbor if you make those
    ...basically a big time hack...create an arbor as the taper and poke the end of a ball mill out the end of that arbor for the tip...not so great as the simulation would then display all red i'm assuming since thats considered a collision?? no other way i can think of??
    is there some other feature or something that will allow the taper mills to be picked from??
    Oct 2007
    446
    so you can create taper mills...but the issue is any of the mill 3axis routines only allow endmill rough and end mill finish tools available ..you can't select a taper mill for these routines ..basically just need a planar zigzag with a taper mill instead of a ball mill....
    anyone??
    May 2013
    701
    Quote Originally Posted by airbrush View Post
    anyone??
    In a 3axis strat wouldn't a center cutting tool be required?
    Apr 2009
    3376
    Quote Originally Posted by RAF. View Post
    Not necessarily if you are thinking outside of the box.
    But Yes,normally,,,but I can think of conditions it would be faster to use a taper EM,,,albeit I never have,,,ex.,,,drafts
    Oct 2007
    446
    guess i'll have to try setting up my hack method and see if its simulates correctly...not sure if it will since technically it will be an arbor (in place of the cutting tool to fake it...) ..so not sure if it will actually remove material in the simulation....
    May 2013
    701
    if I may ask what king of shaped object in a 3 axis strategy would this be cutting
    Oct 2007
    446
    wood project, scrolls/filigree details...I did it in the past with a standard ball mill....but would have rather used a taper mill for it...
    I could just run it with a taper mill and it will probably come out fine...but just wanted to simulate to see what issues or details change as a result of the taper....
    May 2013
    701
    I agree in wood probably would work
    I would thick the calculations for a tapered tool would be huge compared to a ball due the massive variance of diameters from different deg. of tappers
    Good luck
    RAF
  1. Replies: 4
    Last Post: 11-20-2017, 11:23 AM
  2. Tons of end mills, morse taper drill bits, etc.
    By ReaverKS in forum For Sale Only
    Last Post: 08-21-2016, 03:23 PM
  3. Replies: 4
    Last Post: 05-19-2016, 04:10 PM
  4. Stacked precision boring adapter in mills taper
    By gumush in forum MetalWork Discussion
    Last Post: 08-30-2014, 12:41 PM
  5. Planar Finishing - Mills where nothing is to
    By Zuckerbäcker in forum MadCAM
    Last Post: 03-10-2013, 07:47 PM
