585,971 active members*
4,094 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Haas VF8-50 Taper Tool Release Problems
    May 2007
    20
    Need help trouble shooting tool change knock-out. Has anyone experienced a problem with a decrease in force within the knock-out actuator resulting in tools not releasing. If so, what component in the air supply was the cause? We have increased the stoke but it seems to be lacking force?
    Jul 2005
    12177
    Obvious suggestion...check your air pressure. Also check for a sluggish solenoid valve; if the valve opens slowly the air creeps in and the knockout piston does not snap down quickly, the impact is needed for the knockout. If the piston moves slowly at first it takes up the clearance and then just pushes instead of knocking.
    I had this problem on a smaller machine and loosened up the solenoid valve by disconnecting the air line leading to the valve and squirting in a bit of transmission fluid.
    You use the remedy at your own risk!
    Jan 2006
    59
    Do you have coolant through the tool?
    If so, I have seen in the past that coolant can migrate into the clamp spring area. This results in rusted springs, and also when the draw bar is compressed it is not only trying to overcome the springs, but the coolant that may be trapped inside and raises all kinds of havoc with the tool changer!!
    RRL
  1. Has anyone modified an X1 for easier taper release?
    By digits in forum Benchtop Machines
    Last Post: 09-24-2006, 05:55 PM
  2. Taper for tool holders?
    By davidmb in forum DIY CNC Router Table Machines
    Last Post: 10-16-2005, 09:08 PM
  3. 50 taper tool setter
    By utengineer04 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-12-2005, 08:16 PM
  4. BT30 taper spindle to cut tool steel?
    By grantmi1 in forum MetalWork Discussion
    Last Post: 05-31-2005, 05:02 PM
  5. Tool Release Button,
    By Ken_Shea in forum Haas Mills
    Last Post: 08-05-2003, 02:27 AM
