585,729 active members*
4,942 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Wiring advice Nema 34 12 n.m motor, 8' wires?
    Nov 2018
    53
    So I have a Nema 34 12 N.m Hybrid motor. I need to run a disconnectable wire plug at least 8 feet. And i want the connector to be all weather water tight. I found this trailer connector. 7 pins, Would these wires be safe for I think a 5.7 amp motor? Will be running it from a 70v 400watt PSU?
    Also, any other suggestions appreciated. This will be outside and want to take a precautions.
    Randy
    See photo attached
    1943
    Re: Wiring advice Nema 34 12 n.m motor, 8' wires?
    That is fine for the amperage, but I would not call that a weather-tite connector. There is absolutely no gasket and the grommets where the wires enter the connector are not that good. Ok for a trailer, and may be ok for your purpose, but definitely not submersible or suitable for a heavily wet environment.
    Dec 2013
    5717
    I agree with 109jb. Trailer plugs operate in a pretty nasty dirty environment and they work pretty well. The terminals are pretty much self cleaning in that they scrape against each other when plugged & unplugged. If they are greased it does help with the water resistance, I like waterproof boat trailer wheel bearing grease for this.
    If possible locate the plug in a somewhat protected area, maybe with a shield over it? RTV silicone and some shrink tube works well for sealing the wire side of both the plug and socket.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2018
    53
    Thanks, I was worried about amperage. It is not going to be submerged, but being outside. If there was morning moisture or it started to rain, I wouldn't want that to be a failure point. I look into some better sealed options. I just need a connector that can unmount the arm for transport.
  1. Wiring Help Needed for Chinese BOB: Where do these wires connect?
    By tonebag in forum Stepper Motors / Drives
    Last Post: 07-15-2015, 09:09 PM
  2. Replies: 7
    Last Post: 01-10-2015, 01:40 PM
  3. Nema 23 wires
    By Gallchobhair in forum Avid CNC
    Last Post: 04-06-2014, 12:26 PM
  4. advice on longer wires
    By mike hide in forum Joes CNC Model 2006
    Last Post: 09-08-2008, 03:51 PM
  5. autopsy of a 8 wires nema 23 stepper motor
    By AlainB in forum Stepper Motors / Drives
    Last Post: 01-21-2008, 09:06 AM
