585,917 active members*
3,508 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > MACH3 Offsets OFF each time i run to the set location around 30mm each time off!!!
Results 1 to 6 of 6
    Dec 2017
    53
    Hi guys
    :wave:
    Im spending so so many hours on my cnc machine learning mach3 and all the stress of learning mach3 and CNC systems
    I will be posting a few questions and hopefully get some tips!
    Ive spent days, weeks on YouTube and Google etc and on the PC so do loads of work there but sometime posting a question can save you many hours and as ive spent all day on my PC and CNC its time for a quick question!
    Today im learning about Offsets and think my nema23 are working well etc,
    But I need to know this,
    Each time I run the G55 Offset and also the g54 offsets
    They “are off each time” please see photo i.e. they go off around 30mm each time further and further
    Can anyone tell me for sure the most likeliest cause of this?
    Is it missing steps? As this is a pre-owned CNC im not sure of the specs on the orginal timing belt and timing belt collars that fit onto my Nema23s
    15362
    Re: MACH3 Offsets OFF each time i run to the set location around 30mm each time off!!
    Quote Originally Posted by adamfromUK View Post
    Hi guys
    :wave:
    You could be missing steps
    You set up each offset as a new starting position, for it to work how it should, you need to Home the machine and then set your work offset positions
    G90
    G54G0 X0 Y0. start of first part
    Program
    G55G0 X100 Y0. start of 2nd part
    Program
    G56G0 X200 Y0. start of 3rd Part
    You can just use ( 1 ) offset and do this as well
    G54G0 X0Y0. start position
    Program
    G0X100Y0. 2nd position
    Program
    G0X200Y0. 3rd position
    Mactec54
    Dec 2017
    53
    Thumbs up Re: MACH3 Offsets OFF each time i run to the set location around 30mm each time off!!
    Thanks for the reply, i could be missing steps?
    Then all that code?
    im a rookie it doesnt make sense too me
    How long does this mach3 take too learn it is a nightmare to learn!
    i thought i did well setting up the workpoints G54 Home and then in tne middle with G55 but as you can see each time! i go back to the offsets it is off by about 10cm each time
    does anyone know the exact reson whats wrong?
    15362
    Then all that code?
    It's not really Mach3, once every thing is setup in Mach3 to match your machine, then it is all about programing your part installing the program and then setup your work piece and run the operation
    It could be missing steps or the machine may not have been setup correct look for a Video on how to set the steps per either inch or metric what ever you are using, this you can then check to see if the machine moves to the movement you ask it to, for a rough check you can use a ruler with a pointer in the spindle, in MDI ask the machine to move G1X 4.0 F10. and see if it moves the correct amount
    If you are using MM then this number would want to be 100 and the F50. you can use any number you want just watch the F number ( speed )
    G54 is not machine Home
    G54 is a work piece X0 Y0 starting point Home is at a different position on your machine
    This snip is call it work home, but really it is work Zero start point
    If you run the same program more than one time does the positions keep changing or does it say the same
    Mactec54
    Dec 2017
    53
    Just a quik reply and thank you Mactec54, im slowly getting the hang off it all lol, so much too learn, still to cut out something, tomorrow im going to make a decent alumimum probe block! to set the probe height one day at a time as the saying goes!
    I did do some last night with a stainless steel ruler and got it MM pefect but when i upload a g code like a dummy run the new issue is the motors were doing the dummy run very very slow! didnt have router on but the axis were all moving sooooooooooooo slowly?
    wonder what thats all about if cant resolve that new issue will post a new topic maybe
    thanks agin:bat:
    15362
    thanks agin:bat:
    What did you have the feed rate set to F----- or was the program done in inches if it was you would need a G20 at the start of the code for metric G21
    Mactec54
  1. Laser-Cutter X-axis resetting to different location each time.
    By Nickwit in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-25-2017, 09:59 PM
  2. total on time and toal running time in fanuc?
    By maan_sunny in forum Machinery Manuals / Brochures
    Last Post: 01-25-2016, 06:48 AM
  3. problem with crashing using offsets for first time.
    By mioduz in forum Tormach Personal CNC Mill
    Last Post: 05-14-2014, 02:18 AM
  4. Replies: 0
    Last Post: 04-24-2012, 01:46 PM
