I am having problems uploading program files from the SD card on my Calmotion ethernet card, but I think the problem is the Fadal memory??? I can correctly view all the files on the SD card from the machine console and can correctly move/delete files to/from the SD card via my network ethernet.
However, when I delete a file on the machine memory using the NE command, it appears to be gone (deleted), but then it randomly appears again when viewing program library, PR.
I have used RI for memory clear, but the problem persists..., a file I have deleted reappears.
I have uploaded numerous files from the Calmotion SD card and understand its use. The data transfer normally works fine and the programs run on the machine fine. This is a new issue and appears to be the VMC-15 memory acting up???
Is there a master memory re-set/format/etc...? or something else I may try.
Suggestions appreciated... Thanks, Mark.
