Hello,
I plan to convert ooznest ox cnc machine with dual belts to linear rails. The machine is 500x750 mm, and I make PCB`s and some stuff of MDF. I like to mill aluminium max to 10 mm thickness (usually 6 or 8mm). I tried it with this machine, but it is not good enough or rigid. And accuracy of the machine is also problem, and belts.
I was thinking about HIWIN HGR20 linear rails with HGH20CA blocks (two on one rail) for one side of gantry for x or y axis. So it would be two blocks on one gantry.
Or,
use two mini linear rails with two blocks on one side (like HIWIN MGN09H), so it would be for blocks on x or y gantry.
What do you guys think, what is the better solution?
Aleksandar
