585,975 active members*
4,957 visitors online*
    Jul 2014
    221
    Five axis simultaneous milling
    Hi, I would like to know how to compensate for a fixture in a five axis milling program. I've got a 5 axis trunion table in a Haas VF2 mill, there is a vice in the machine which moves the part out of the centers of rotation (A axis tilt and B axis rotary table), I would like to know how to compensate in a Solidcam to make the milling parts 5 axis sim milling, because the part is, for example, moved, 30mm left of the center of the rotary B axis (rotates 360 degrees around Z axis) and about 40mm above A axis' center of rotation? In a Solidcam program I have to compensate for that translation from centers of rotation of axes, but I dont know how. I'm using gmill haas5x eval postprocessor.
    Mar 2018
    This would be compensated via machine dynamic offsets.
    Look at this https://www.youtube.com/watch?v=HxPjH4v5iEg
    Mar 2017
    24
    Re: Five axis simultaneous milling
    In your machine setup you can tell SolidCAM where your MAC sits relative to the machine zero. The XYZ in the machine setup is to input the incremental distance of the MAC from machine zero. This will be used like the pivot point and allows for offset coordinate systems. You can also set your fixture there as well. I hope this answers your question.
  1. Replies: 1
    Last Post: 07-09-2018, 05:47 AM
  2. Can TNC 407 Do simultaneous 4 axis cut
    By Behnod in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-27-2017, 02:02 PM
  3. Replies: 2
    Last Post: 02-07-2016, 06:08 PM
  4. Need help with simultaneous 4th axis
    By mgmcnc in forum FeatureCAM CAD/CAM
    Last Post: 10-24-2013, 03:53 AM
  5. 4 axis simultaneous milling
    By svarzaru in forum FeatureCAM CAD/CAM
    Last Post: 07-05-2012, 05:33 AM
