Originally Posted by
jdgromi
Hello! en need help
My project is 3 grooves at 120 degrees around a cylinder, my 4th axis revolves around Y axis. I use Mach3 on my Router, SolidCam and Fanuc_2013_4X as a postprocessor to generate the G-Codes. The problem: My router works the first groove but is not able to do the other 2. The G-Code is not correct. He makes the first groove, he indexes at 120 degrees and returns to zero to make the 2nd. In the end, there is only one groove, the one at A0. What is the problem? The * .vmid file, the post-processor, Mach3. The simulation on SolidCam is perfect.
