585,975 active members*
5,045 visitors online*
IndustryArena Forum > Business Practices > Business Practices / Pricing > Secondary Operations on Small Stamped\Lasercut\Water Jet Parts
    Jun 2006
    7
    Hello,
    I'm an engineer working on a design for a robot operated CNC machine specialized around secondary operations. However, I'm not a machinist so I'd love to know what the economics of these kind of operations are. I'm wondering if you guys can share some of your experience on what these operations are typically priced at and what the real difficulties are when manufacturing them.
    Here's some example operations:
    Bringing outside profile into tolerance/removing burr from stamping operation.
    Attachment 409530
    Cutting a pocket into the part:
    Attachment 409532
    Engraving Logos, Company Names, Part Identifiers, etc:
    Attachment 409534
    My hope is to reduce the cost of secondaries/high cycle time small operations down.
    Thanks!
    Jan 2017
    13
    Re: Secondary Operations on Small Stamped\Lasercut\Water Jet Parts
    If you are stamping the parts then proper die design should be able to over come all your secondary operations, for laser and waterjet then it comes down to quanitys allowing for investment in better fixturing.
  1. Small Aluminum Production Parts... Small VMC work
    By Neuxstone in forum North America RFQ's
    Last Post: 04-08-2019, 05:52 PM
  2. Lasercut 1/4" Steel Plate - 2 parts, Qty 10 each
    By sanddrag in forum RFQ (Request for Quote)
    Last Post: 01-28-2013, 05:06 PM
  3. Brass pieces to be cut or stamped.
    By Ty G in forum North America RFQ's
    Last Post: 10-14-2012, 07:37 PM
  4. RFQ small aluminum pieces both mill and water/laser jet parts
    By ahaidet in forum Employment Opportunity
    Last Post: 02-04-2011, 03:05 PM
  5. Replies: 4
    Last Post: 12-15-2009, 12:13 AM
