585,733 active members*
5,168 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas Vf2 8100-rpm or 10,000-rpm Spindle
Results 1 to 6 of 6
    Jan 2012
    9
    Hello everyone.
    I'm looking for a VMC to work with aluminum, brass and soft steels. Haas has the vf2 with the option 8100-rpm or 10000rpm spindle and I'm not sure if the cost of the upgrade to 10000rpm is worth it. What would be the main difference?
    Can someone give an advice?
    Thank you.
    Jun 2003
    1365
    Re: Haas Vf2 8100-rpm or 10,000-rpm Spindle
    It appears they run the same motor. If you're cutting aluminum or steel with small end mills you'll use all the RPM. If you're doing production it's a no brainer to get the faster spindle.
    Jan 2012
    9
    Thanks JFettig.
    So if I use bigger end mills will the 8100rpm be enough? Yes I want to do production but my budget is limited...
    May 2015
    8
    if you're cutting with under 20mm , I'd go with 10k or more
    Feb 2007
    171
    The 8k rpm machine will have more torque but for what you are using it for, I would definitely upgrade to the 10k spindle. The 8k spindle is the same as the 10k spindle so you won't need to exchange it for a 10k unit. FYI: We have replacement spindles for all VF machines if you happen to need one. $2,995. All RPM's thru 12k, 208-888-9236.
    Aug 2005
    235
    Go with 10K. I run 1" insert endmills at 12K in aluminum all day. I do believe however that it is nothing but a parameter and can be purchased later. Your HFO may be able to better answer this.
  1. Haas VF2 way/spindle oil?
    By dwilley in forum Haas Mills
    Last Post: 03-21-2019, 04:06 PM
  2. Haas HL-4 Spindle
    By TFF-UK-LTD in forum Haas Lathes
    Last Post: 02-14-2011, 02:37 PM
  3. sodick 8100 technical documentation
    By Gerry1955 in forum EDM Discussion General Topics
    Last Post: 08-09-2009, 09:56 PM
  4. avago aedr 8100 reflective encoder question
    By daedalus in forum Servo Motors / Drives
    Last Post: 07-09-2006, 04:27 PM
  5. Just got a Haas VF1 with 30k spindle
    By rhettmandel in forum Haas Mills
    Last Post: 01-22-2006, 01:32 AM
