The spindle turns freely when the power is off. I looked at a post that I think you helped someone out with settings.
I tried to copy them but it dosnt seem to work.
I added them as: D000=400
D001=1 (
May be D000=0 by Default this will lock any Parameter Change )
D002=400
D003=400
D004=220
D009=400
D010=100
D011=10 ( Default=10 Adjustable Acceleration )
D012=10 ( Default=10 Adjustable Deceleration )
D031=0 ( Default=0 For Keypad use (1 ) for Remote Control )
(D031 May need to be set to 4 D031=4 Depending how your Control is being used)
D032=0 (Default May need to be set to 1 D032=1 Depending how your control is being used )
D033=0 ( For Keypad Stop ( 1 ) If Remote Control is being used )
D036=1
Then similar happened so I changed
D031, 32 & 33 =1
& still the same happened.
On the last attempt I did se the spindle turn ever so slightly & then it said error on the display screen.
Its so frustrating lol
