585,975 active members*
4,612 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, what is causing this error : 9135 igf data can't be edited while selecting NC ..
    Jun 2015
    4154
    hello please, what is causing this error : 9135 igf data cannot be edited while selecting NC PROGRAM sheet
    * screen attached / kindly
    Jun 2018
    362
    Re: pls, what is causing this error : 9135 igf data can't be edited while selecting N
    Not familiar with your software but that type of error is usually indicative of trying to edit a file that is already open by another program or other facility.
    Aug 2011
    419
    Quote Originally Posted by he1957 View Post
    Igf versions are mismatch
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    hello he, hy kurmay i searched a bit, and "NC program sheet" seems to be the list of files located inside MD1, or something? related to them
    this error seems a bit weird, because igf targets the AD0 folder, while "NC program sheet" targets the MD1 folder
    i was asked to help about this issue, but i did not know what to do, and also it was not known what keystrokes were pushed, so to cause this
    in the end, after 2-3 power on-off, all seems to be ok ... for now
    there is no documentation for such errors, displayed like this, inside a window, but only for those that are listed near the screen top, on red background
    whatever / kindly
  1. error 368 X AXIS : SERIAL DATA ERROR (INT)
    By mattpatt in forum Fadal
    Last Post: 02-24-2023, 02:01 PM
  2. Z70 Abs. Data Error 0001 Z1.
    By dany_riv in forum CITIZEN Machines
    Last Post: 11-13-2021, 11:59 PM
  3. ESS Out of Data error...again!
    By Goonk in forum Avid CNC
    Last Post: 08-15-2017, 08:12 PM
  4. arc data error
    By slowdigits2 in forum G-Code Programing
    Last Post: 11-25-2014, 10:39 AM
  5. CAM M2- Error 100 tool data not set
    By tomtheslacker in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-25-2008, 05:47 PM
