585,690 active members*
4,808 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Miyano BNE 51SY Lathe (Synch dual turrets)
    Jan 2019
    4
    Hello, The company I work for has a Miyano BNE 51SY lathe, and I'm new to this type of machine. I have limited experience with a dual turret / dual spindle lathe and I'm just trying to get familiar with the m-wait codes. I have ran both heads on the lathe, but not simultaneously. Just wondering if there were any Miyano gurus that could help me wrap my head around the process of structuring the sync process. The sub spindle is B axis, I have done some engraving with the C axis as well as milling with the live tooling, my main problem is trying to sync everything together. Looking for proper program structure in order to get both heads working at the same time. Clearance is not an issue because as most good lathe guys know, clearance is one of the first things you master when working on a lathe. Any input would be appreciated. Thanks.
    May 2003
    323
    Re: Miyano BNE 51SY Lathe (Synch dual turrets)
    Can't send you PM
    Sent from my MHA-L29 using Tapatalk
    Jan 2019
    4
    I turned on PM, It was set to off by default.
    Jan 2019
    4
    The original post has been resolved. Thank You.
  1. Pros & Cons of new and old lathe turrets?
    By MichaelHenry in forum Tormach Slant Lathe
    Last Post: 06-02-2016, 12:48 AM
  2. Robust CNC lathe Turrets
    By experto crede in forum News Announcements
    Last Post: 08-21-2012, 08:25 AM
  3. EUROTECH Dual and Tripple Turrets Machine
    By EUROTECH in forum News Announcements
    Last Post: 09-22-2009, 02:50 AM
  4. miyano dual spindle lathe
    By terrywinstr in forum Community Club House
    Last Post: 02-09-2009, 02:14 AM
  5. Restart of integrex eia program with dual turrets
    By Bobc007 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2007, 01:43 AM
