495,955 active members
8,313 visitors online
Results 1 to 2 of 2
    mikemccand
    Guest
    Good source online for cast acrylic sheets to cut with CO2 laser?
    I'm trying to find a reasonable cost, good quality source for cast acrylic sheets (1/8" - 1/2" width), 24" x 48".
    I have bought a few sheets from Amazon, and they cut well, but took quite a while to ship to me and were fairly expensive (though possibly that's just how much cast acrylic costs).
    I just tried to order from Professional Plastics (https://www.professionalplastics.com) but had a bad experience and wound up cancelling the order.
    I'm considering Acme Plastics (https://www.acmeplastics.com/) now.
    Can anyone share where they order their cast acrylic sheets from?
    Gold Member
    Jun 2006
    2932
    Re: Good source online for cast acrylic sheets to cut with CO2 laser?
    24x48 anything is going to cost quite a bit to ship and you can save quite a bit if you buy local and pick it up. Try Googling "acrylic sheet near me" and you should get a few hits. If you happen to be in an area served by McMaster-Carr, I've had good luck with cast acrylic bought from them.
    mcmaster.com
  1. Chinese Acrylic Sheets Supplier
    By wolfau in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 04-17-2013, 09:36 AM
  2. How large air compressor to use for cast acrylic?
    By Metalmidget in forum Tormach Personal CNC Mill
    Last Post: 09-06-2010, 08:04 PM
