585,754 active members*
3,804 visitors online*
Results 1 to 6 of 6
    Aug 2018
    44
    Laser not cutting exactly vertically
    I cut through 1/2 acrylic and the part (a snowflake) came out well, but I noticed that the laser is not cutting precisely vertically, but rather at a small angle.
    I also pulsed on the edge of a 2 x 4 and saw the same thing.
    Has anyone else hit this? It seems like I need to adjust the mirror on top of the laser head just a bit -- any suggestions?
    Jan 2008
    940
    Re: Laser not cutting exactly vertically
    On my 60 watt if I have the beam hit the center of the final mirror I get an angled cut. I had to lower the lens assembly just a little so the beam hits higher up and that did the trick. I checked by test firing at the focal length then lowered my table and fired again and the spot hit way off.
    Mar 2018
    11
    Depending on the angle you're seeing, this might be "working as expected". When calibrated correctly, the laser beam produces an hourglass shape at the vertical center of your material so getting a precise 90 degree edge is going be impossible on 1/2". On thin materials this is barely noticeable. You can get a nicer edge with a lens that is suitable for cutting thick materials, e.g. a 4" focal length lens.
    Sep 2018
    83
    You'll always get a slight vertical taper when viewing cut material in profile. It's a combination of beam focal length and the loss of energy as it passes through solid material.
    1/2" acrylic will have quite a pronounced taper to it. One way og etting round it is to look at setting the focal point about a third of the way into the material, so if it's a 9mm sheet, set it 3mm deep, as opposed to the top surface of the material. I've had mixed results with this trick, but it has worked well in some instances, so might be worth a try
    Jan 2019
    5
    Depends
    If both edges of a cut disk for example face the same slant direction then it would be lens astigmatism so the z axis optical path is not parallel. If cutting again the same disk the edge angles are opposite then its a case of playing with the focal point to get to the centre of the beam waist.
    mikemccand Guest
    Thanks for the replies. I am using the 4" focal length already, which I thought should have less hourglass taper effect, but maybe in fact what I'm seeing is "by design". It isn't such a big deal in practice; I don't cut 1/2" thick material so often.
  1. Replies: 0
    Last Post: 09-20-2016, 12:54 PM
  2. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2015, 09:03 AM
  3. Machine mounted vertically on the wall?
    By Woodphizeau in forum Uncategorised WoodWorking Machines
    Last Post: 01-09-2014, 07:28 AM
  4. Anyone using THK SR30's and have then mounted vertically for x or z axis?
    By blau_schuh in forum Linear and Rotary Motion
    Last Post: 12-31-2006, 10:13 PM
