585,763 active members*
4,141 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor specs and information ?
    Jan 2019
    Question Stepper motor specs and information ?
    I have 4 of what I believe are Nema 23 though I am not positive as I don't have any specs on them.
    1) Motion Systems Stepping Motor 57HY55DF2DL (2006 - 12 - 29)
    2) Motion Systems Stepping Motor 57HS55DS075A (2006 - 12 - 29)
    3) Stepping Motor Type 23HS2417 MSW0-62953 MOONS
    4) ASTROSYN Stepper Type 23KM-K355-33 No. T9921-01 Minebea Co. LTD.
    Also, all these stepper motors have gears on them, only #4 has a set screw. The others are pressed on. Is there a way to remove these gears without going to a lot of expense.
    Mar 2015
    409
    Re: Stepper motor specs and information ?
    • You could try to remove the gears using a (self made) puller, don't use a hammer!
    • A bit of heat could help. Don't over heat or the bearings and stepper coils are gone...
    • Cut a slit (Dremel) almost to the axis, then break the gear using a v-shape tool (Nut splitter)
    Feb 2019
    Who can confidently pick the best product among those listed on this site?
    https://rainydayfitness.com/best-stepper-machines/
