Hello everyone.
I do have a ht20s2 with yasnax lx3bt controller.
The accuracy of the machine x-axis is at +-0.02 mm which is very Bad for most of the parts i do.
I already checked the encode, switched the Motors from Z and X Axis. Also switched only the encoder.
I also checked the backslash which seems to be good.
Another problem in connection to the accuracy is when changing the X-axis tool wear. Lets say my diameter is 20.01mm and i want 20.00mm i am doing a tool length change for the X-axis of 0.01mm. But the part just stays the same or it just jumps to a different value like 19.98 or 20.03.
I also checked the turret positioning accuracy which is fine.
The only thing i am thinking of are the x-axis linear rails. Can the play in the rails be adjusted?
Maybe someone can help me out. I am from Germany by the way.
Thanks for the help.
