585,977 active members*
4,603 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > HT20S2 X Axis Accuracy problem
Results 1 to 2 of 2
    Sep 2008
    12
    Hello everyone.
    I do have a ht20s2 with yasnax lx3bt controller.
    The accuracy of the machine x-axis is at +-0.02 mm which is very Bad for most of the parts i do.
    I already checked the encode, switched the Motors from Z and X Axis. Also switched only the encoder.
    I also checked the backslash which seems to be good.
    Another problem in connection to the accuracy is when changing the X-axis tool wear. Lets say my diameter is 20.01mm and i want 20.00mm i am doing a tool length change for the X-axis of 0.01mm. But the part just stays the same or it just jumps to a different value like 19.98 or 20.03.
    I also checked the turret positioning accuracy which is fine.
    The only thing i am thinking of are the x-axis linear rails. Can the play in the rails be adjusted?
    Maybe someone can help me out. I am from Germany by the way.
    Thanks for the help.
    Nov 2017
    19
    Re: HT20S2 X Axis Accuracy problem
    Just a shot in the dark but I had a problem with my KV turret machine that had symptoms like this when the tools weren't being clamped fully. The clamp/unclamp hydraulic cylinder became stuck and wouldn't travel all the way back. This caused the tool holders to not clamp fully. I made a whole run of parts (with threads!) like this and couldn't figure out why they were so inconsistent. It took a lot of force to see the holder move.
    Rebuilding the cylinder was the fix.
    In terms of linear rails, pretty sure they are a throw-away item. The Hitachi parts manual lists them from the actual manufacturer so you don't need to rely on a dead company (IIRC).
    Good luck
  1. C-Axis Problem HT20S2
    By j_love in forum Mori Seiki lathes
    Last Post: 08-29-2022, 08:01 PM
  2. Problem with Z-Axis accuracy?
    By Kosh in forum Avid CNC
    Last Post: 09-18-2016, 10:31 PM
  3. Hitachi Seiki HT20S2 502 Alarm
    By blakemachine in forum Hitachi Seikis
    Last Post: 03-02-2015, 01:55 PM
  4. Best way to fix accuracy problem
    By bmantz in forum Uncategorised MetalWorking Machines
    Last Post: 06-14-2011, 03:34 PM
  5. Hitachi Seiki HT20S2 / Yasnac LX3
    By cncmach15 in forum Mori Seiki Mills
    Last Post: 02-07-2011, 09:50 PM
