585,741 active members*
5,183 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Ball screw info, disassemble or breakdown image.
    Oct 2008
    115
    Hi guys, been a while since I've been on here.
    I have a question about ball screws.
    I have an X3 that I converted a few years back with an CNCfusion kit.
    I'm looking for info on how the ball screws are assembled or maybe a break down image.
    I'm trying to figure out what the set screws in the sides of the ball screw end are holding? There are 2 at 90 degress to each other. Do they hold that white plastic scraper ring in?
    https://drive.google.com/file/d/1-9r...ew?usp=sharing
    Cheers,
    Nov 2012
    1267
    Re: Ball screw info, disassemble or breakdown image.
    Those holes are for lubrication. The set screws just plug the holes.
    Dec 2005
    436
    The empty holes are oiling.
    The holes with setscrews....the setscrews hold the white plastic wipers( which keep debris out of the insides)
  1. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  2. Adding ball screw to lathe for Electronic Lead Screw
    By harrzack in forum Hobbycnc (Products)
    Last Post: 12-28-2018, 03:28 PM
  3. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  4. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  5. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
