I have the MG103 up and running. Now I need to source some more tools. The spindle is a Colombo RC 110.22. I see pull studs listed on the Multicam site as being for the RS and Billet spindles. The one tool that was in the spindle suggests the drawbar uses fingers. I'm not sure which pull studs to order.
I'm also only able to use a few of the pockets on the carousel because of extreme wear. Pocket #1 for example droops too far to reliably change, but pockets 6-8 are perfect. I found a replacement carousel but it is for 7-10 HP Colombo and mine is 5.5HP. It certainly looks correct. Part number is: 911P4458-0
https://store.multicam.com/ProductDe...ode=911P4458-0
I have the 10 HP turbo vac plumbed in. The waste board warped in transit and is cut up. What kind of MDF should I source? Also, when I block the suction at the filter the the vacuum gauge goes to about 15 inches and the motor draws the full 24 FLA. With a board over one quadrant I can only get 4-5 inches. What kind of vacuum should I typically expect?
Thanks in advance.
