Hello, we have DMU 80p with swiveling head, and the problem is next: When i switch to manual rotation in 3d rot menu, Y and Z axis compensate some value for about 3mm, X stays the same... and the problem is that i dont have active any rotation or something similiar, i am using for example machine for 3 axis machining, set the zero on the piece, and when i start the program, post creators puted always cycle 19, even if values are C0 A0.... and when cycle 19 gets activated on C0 A0, zero on the piece that i want to machine, mismatch... when i delete cycle 19, everything is cool, but i have problem when working with swiveling head and C and A axis on complex parts...
Manual operation: Inactive
Manual operation: Active
On the same position... tried switchin on other similiar machine, on them values are always the same when there is any rotation affected...
