585,763 active members*
4,506 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Vfd 415 motor 240v supply.
Results 1 to 10 of 10
    May 2013
    149
    Hi, i saved a 5.5kw, 2 pole, 2850rpm, 415v, 10.2 amp motor from the bin at work, its wired delta.
    Can i run this as 240v 3 phase on a single phase vfd?
    Is this easy to match the vfd?
    Many thanks for reading.
    Apr 2015
    170
    Re: Vfd 415 motor 240v supply.
    Are you sure it is delta, small three phase motors that use a 415v supply are usually wired star which would allow you to connect as delta for 240v three phase. Dave
    ericks Guest
    Can you post a pic of the motor plate?
    Apr 2015
    170
    Quote Originally Posted by ericks View Post
    Also a pic of the internal connections in the terminal box.
    ericks Guest
    Quote Originally Posted by Bdrangdo View Post
    That would be nice
    May 2013
    149
    Its still dark, after work i will open her up.
    Edit;
    The wires appear to be not bridged in any way.
    Apr 2015
    170
    It does look like it is delta connected for 415v, it is probably designed to be used with a star delta starter. You can get inverters that will step up to 415v from 240v but they are pricey for a motor that size, they sell for about 1500 GBP in the UK. Dave
    May 2013
    149
    Thanks Dave, i may have sell and buy another.
    Edit;
    It appears to be star delta starter setup, i dont have access to a multimeter until Friday night.
    ericks Guest
    Quote Originally Posted by Zenji View Post
    Edit;
    Its a delta motor at 415 so sorry you shouldnt use it cause supplying 230v will cause much reduced torque. Best to buy the correct motor
    May 2013
    149
    Afraid so, thank you to all who posted.
    Wisdom results from foolishness!
  1. 480v Inverter On 240v Motor
    By HillBilly in forum Spindles / VFD
    Last Post: 12-30-2015, 07:16 AM
  2. hurco KMB1 on UK 240v supply.
    By adee1066 in forum HURCO
    Last Post: 12-15-2013, 03:08 AM
  3. Moeller DF6-340-15K on domestic 240V supply
    By ceefna in forum Phase Converters
    Last Post: 11-21-2011, 02:54 PM
  4. 160V DC 12 Amps from 240V AC single phase supply
    By ftkalcevic in forum CNC Machine Related Electronics
    Last Post: 04-27-2010, 05:07 AM
  5. 240v supply and 208v motor
    By isu19151@verizo in forum Bridgeport / Hardinge Mills
    Last Post: 11-29-2007, 08:23 AM
