585,663 active members*
2,974 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Deckel maho 80U (1999) millplus E252 error
Results 1 to 8 of 8
    Oct 2012
    23
    I have got this E252 alarm (tool in toolchangerarm).
    Its not possible to do a toolchange with M6, but if i do a M66 (manual change) and then a M6 directly after the ATC will work once.
    Any suggestions to fix this?
    I have tried the I/O recovery of toolchanger but too no help.
    Oct 2018
    11
    Re: Dmg mori 80U (1999) millplus E252 error
    Hi, this just says there is a tool in the tool gripper, depending on the version of machine, you may have a proximity switch on the gripper giving you an incorrect status. Check and see if there are any proximity switches on the tool changer monitoring the grippers and let me know.
    Cheers
    Jul 2008
    7
    Re: Deckel maho 80U (1999) millplus E252 error
    hello,
    Please, have you debug alarm E252 ?
    I m from Romania and I have the same problem like you.
    In fact after parameter loose , I reload all parameters and after restarting when I set M 6 or M66 I have E252 (tool already in gripper) but my DMU50V dont have gripper tool changer !!!
    Thank you for helping,
    Ion
    Feb 2020
    18
    Hello ,
    I am also getting this error E252 tool in toolgripper alarm ( DMU 60T - Millplus 1999 model)
    After loading parameters & BIOS in battery problem.
    No sensor in tool gripper. Checked all PLC IOs , its ok.
    I think somewhere system memory, gripper has to be reset.
    Please guide for this problem.
    My email is [email protected]
    Regards
    Senthil kumar
    Feb 2020
    18
    please send your email address
    i am getting your same message alarm.
    Nov 2021
    Hi, Have you found the solution to this problem? I have the same problem.
    Sep 2019
    11
    ANY SOLUTION I HAVE THE SAME PROBLEM
    Sep 2019
    11
    I managed to solve the E252 error.
    I turned the machine on and press delete.
    Then heidenhain numeric service menu appeared.
    From there i selected 6. Load default machine constants and clear all memories.
    After I needed to import all machine parameters.
  1. Millplus error
    By bassplayerfred in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-24-2018, 10:47 AM
  2. Millplus error X15+
    By fsa in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-14-2018, 07:31 AM
  3. DMU 50V Millplus error E60
    By paris in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-01-2017, 09:46 PM
