Wear Offset vs Actual Tool X Position
Got a question for the experts out there. In PP on the lathe you have adjustments for wear offset in X and Z. My question is when should you adjust wear offset vs updating the tool offset. The reason this came up was that this morning I was checking some parts and doing a quick X calibration due to cold as dog snot shop temp when I realized my manual cut was not matching my programmed cut. My assumption is that wear offset is called up in the program as G41/G42 and that a manual cut does not take this into account. I applied the wear offset to the actual X offset, went back to the wear offset and zeroed it out. Now my manual cut was the same as my programmed cut.
So, I'm assuming this will fall into the "best practices" to follow.....?
Thoughts?
Later,
Awall
The Body Armor Dude - Andrew
