584,861 active members*
4,979 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Desktop injection molding machine lever design
Results 1 to 5 of 5
    Feb 2017
    I'm building a desktop injection molding machine like in this image but i'm confused about the lever design is it second or third class?
    I know that the force is 12000 PSI , How can i calculate the arm length?
    2505785bc44b79cfea144ec1c788e973 — imgbb.com
    Dec 2015
    15
    Re: Desktop injection molding machine lever design
    Second class -- if that somehow matters.
    All such calculations are simply a matter of Force x Distance = Force X Distance, regardless of where the fulcrum is located.
    You'll need to know plunger diameter to calculate psi loading. Gotta know the square inches, there.
    Feb 2017
    My plunger diameter will be 15 mm, How can i calculate psi loading?
    Jun 2011
    692
    Convert to inches (/25.4) then divide by 2 (radius,) square and multiply by pi (area formula.)
    May 2015
    1422
    12000 PSI is the pressure in pounds per square inch. Multiply it by the area on which that pressure is acting (ie the piston face) gives you force in pounds. That force divided by the force you want swinging on the handle (what, 60lb max?) is the gain the lever needs. Which in turn gives you the length of the handle.
  1. Dr.Boy 25e injection molding machine
    By sizala in forum Plastic injection
    Last Post: 07-27-2016, 05:51 AM
  2. Movie Injection Molding Machine
    By mostafasobhey in forum Videos
    Last Post: 06-28-2012, 06:13 PM
  3. Replies: 2
    Last Post: 06-23-2007, 01:57 AM
  4. injection molding spoked RC wheels: mold design?
    By chris_b in forum Hobby Discussion
    Last Post: 02-19-2007, 08:45 PM
