586,009 active members*
4,744 visitors online*
    Nov 2018
    53
    Advice on my Large Scale Z axis
    Greetings again!
    Well I'm well on my way to figure out how my "X" axis (actually it isn't X, will attach to my Z tower. The Z tower is a 12" square aluminum truss with 2" diameter tubes, 2 meters tall. The X arm is a 9" triangular truss with I think 1.5" tubes. This will be belt driven.
    Originally i was going with SBR20 linear rails for the Z, but after much reading about binding, I am going with a simpler tried and true design used in most 3D prints. Please see my diagram. I am using larger Delrin wheels and bearings. Transferring some of the load to the rear of the truss.
    I designed this bracket.
    Cost is a factor but what are your thoughts on going with aluminum or sheet steel? I will see about getting this plasma or waterjet cut. Then bent.
    What do you think would be a good thickness? 1/8"?
    I'm not an expert in Aluminum alloys 6061? 5052?
    I'd like to be able to adjust the tension, but also be able to adjust the right angle of the X arm if I'm off.
    i will have an aluminum base-plate which is made by the manufacturer of the Truss, so it keys in perfectly. That way, the arm can be easily broken down for transport.
    Thanks for any advice.
    I think I will also move the belt drive to the rear rather than originally where the two truss join.
    Thanks!
    Dec 2013
    5717
    Re: Advice on my Large Scale Z axis
    I would make the bracket in 3 pieces out of 1/2 inch 6061. Bolt the pieces together with 5/16 cap screws. Or you could just bolt the ''wings'' to the supplied bracket if there is room. If you want to reduce the weight, cutting out a large hole in the center of the ''wing'' would work well.
    For adjustable rollers, I would use cam followers pressed into the delrin rollers. The cam followers are available with adjustable position. https://www.mcmaster.com/cam-followers
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2018
    53
    Jim!
    Your advice is gold. I wouldn't second guess you. That was my 6AM sketch. I will do cutouts and refine it more. I'll do a cardboard mock up next and see how well it fits.
    Thanks again!!!
  1. Large Scale 3D Printing
    By Andrew22 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 12-20-2016, 04:23 AM
  2. Replies: 1
    Last Post: 10-02-2015, 05:34 AM
  3. Parker HZR100 for large scale machine Z axis?
    By kentster in forum DIY CNC Router Table Machines
    Last Post: 08-03-2011, 09:58 PM
  4. Looking for a large scale Fabricator
    By MVJKstudio in forum Employment Opportunity
    Last Post: 08-05-2010, 08:03 PM
  5. Heavy large scale gantry mill/router/3d carving 5 axis build
    By Tristar500 in forum DIY CNC Router Table Machines
    Last Post: 03-18-2010, 12:07 PM
