585,589 active members*
2,858 visitors online*
    Jan 2018
    4
    positioning problems
    hi guy
    I have problem with my cnc
    when i move the X and Y axis in (+) it miss the zero point by 1 mm
    but when i move it in (-) the X and Y it go back in zero point with no problem
    can anyone help me
    Oct 2005
    73
    Re: positioning problems
    Sounds like your machine has backlash. You could check if the screws are moving axially or if they turn a small amount before the table starts moving.
    May 2005
    3920
    I’d most certainly be looking for backlash also. It could be in the leadscrew nuts or in the leadscrew thrust bearings. Don’t dismiss other things though like loose serscrews, software settings issues, or issues with the linear bearings that you are using. Too much slop in the linear bearings can lead to the saddles rocking as the direction changes leading to displacements that look like bachlash.
  1. Way to get Incremental G91 positioning?
    By O-MX45VAE in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-08-2018, 06:40 PM
  2. Video Positioning
    By KOS in forum Mach Software (ArtSoft software)
    Last Post: 11-29-2007, 12:23 AM
  3. Need help with motorized positioning
    By xshaper in forum Work Fixtures / Hold-Down Solutions
    Last Post: 11-26-2007, 12:38 AM
  4. *** Positioning Problem ***
    By baran3 in forum Community Club House
    Last Post: 01-27-2007, 02:49 AM
  5. Fanuc O-M positioning
    By 723 in forum Uncategorised MetalWorking Machines
    Last Post: 07-31-2004, 02:09 AM
