585,722 active members*
4,148 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Machine seems to actually work now... What now?
Results 1 to 13 of 13
    Jan 2010
    78
    So I had my Partner 1 sitting in my garage for almost 10 months now. After replacing the X axis cable today, it seems to be functioning.
    The problem is, I have no idea on how to operate the machine or to check if everything is actually functioning correctly. Is there a series of check i can go through to see if the machine will operate?
    I am not sure on how to turn on the spindle to see if it will operate, or jog the X, Y, and Z axis. Is there somewhere I can look for basic instructions on operating the machine? I have Centurion V controller.
    I want to start with writing very basic programs in MDI/conversational mode to learn the system before trying to run an actual program. As I am learning to use CAM software currently.
    Sep 2010
    529
    Re: Machine seems to actually work now... What now?
    Turn on the spindle: MDI, type in M03 S1000 input and then hit the start button. After you do that the first time after power up, you can use the spindle CW and CCW buttons.
    Move an Axis in rapid: G00 X-10, input, then hit start.
    Move an axis in feed rate: G01 X-10 F20., input, then start.
    You will need to learn to get tool dimensions, G54 (home position on the part) and aa host of other things. As for the conversational side, I really don't use mine so others will have to give comments there. Do you have the operators manual? It has all sorts of programming examples.
    Jul 2006
    130
    Do you have tools? Tool holders? Vise?
    Jan 2010
    78
    Awesome thank you. I was able to get the spindle to turn for the first time! Might not sound like much. But it's a big step forward for me.
    One thing though. When homing the machine, only the Z axis homed. Nothing else moved. Not sure why? Even the screen read "Homing Z axis". Nothing mentioned about X or Y.
    Yes I have tooling, Vice, tool holders, etc. Just waiting to be used. I want to get a good grip on operating the controller before I attempt to make a part though.
    Mar 2017
    63
    What's your email. I have a pdf work book for learning the mill conversational.
    Sent from my SM-N960U using Tapatalk
    Jan 2010
    78
    Quote Originally Posted by bmoore View Post
    [email protected]
    Thank you!
    Sep 2010
    529
    [QUOTE=sen2two;2254038]When homing the machine, only the Z axis homed. Nothing else moved. Not sure why? Even the screen read "Homing Z axis". Nothing mentioned about X or Y.
    There are parameters in the machine for which axis homes and in what order. I have mine set to home as it should, to the home switches, but it wouldn't be the first time I've seen a machine where all they do is home Z and then just set 0,0 in X and Y wherever the corner of the part is and work from there. You have to type on a password to get into the parameters, can't remember as I have it written down outside, but "Proto" and then "3" comes to mind.
    Jan 2010
    78
    I think I found this area to set the home sequence. Only the Z axis had something in this setting. I think it was 90. I believe it's supposed to be:
    X - 88, Y - 89, Z - 90
    Correct?
    Mar 2017
    63
    I think it's in parms-control homing sequence
    Should be
    Z=1
    X=2
    Y=2
    Jul 2006
    130
    Never dawned on me I could have x and y home at the same time. Mines Z X Y in that order.
    Mar 2017
    63
    Mine is
    Z=1
    X=2
    Y=2
    A=2
    Jul 2010
    548
    Hi Sen2, You should call me when your in front of the machine.
    sportybob
    Jan 2010
    78
    Will do. I appreciate your help.
  1. I need help getting my CNC machine to work
    By geneiusxie in forum Controller & Computer Solutions
    Last Post: 12-23-2013, 12:29 AM
  2. CNC Machine Work
    By betch23 in forum North America RFQ's
    Last Post: 04-29-2013, 01:56 PM
  3. My new machine....needs work....
    By G. Hoffman in forum CNC Wood Router Project Log
    Last Post: 09-15-2012, 01:33 AM
  4. Machine Down Need work done
    By Bluesman in forum Employment Opportunity
    Last Post: 09-28-2007, 01:52 PM
  5. Getting work(gcode) from machine a to machine b
    By strat in forum DIY CNC Router Table Machines
    Last Post: 07-07-2005, 08:13 PM
