502,973 active members
5,838 visitors online
    Registered
    Feb 2011
    11
    Adding notes to individual tool paths when using the same tool
    I'm using the same tool for multiple operations and I'd like to find a way to add notes to mark when the new operation starts while I'm using the same tool. Like "small pocket, "large pocket", "island".
    I've searched and really had no luck. I'm not even sure if this is possible.
    Any help would be greatly appreciated.
    Flies Fast
    Dec 2008
    2790
    Re: Adding notes to individual tool paths when using the same tool
    put your comment on the end of the operation in op manager.... or in the tool parameter section of that operation.
    Your post has to have the ability to parse it into the NC file.
    The only problem it cannot overcome is when doing individual features in the same operation.... those ( if needed) must be edited in manually
    Registered
    Feb 2011
    11
    Thank you. That helps immensely.
    I saw the comments section but didn't realize it would output a note for each operation using the same tool and not just at the beginning of each tool.
    I'm still learning. I'm able to use Mastercam after work at my job, but I get no help from anyone. I've been fumbling around and making progress watching youtube videos. Slow going but I'm getting there. I bought a Fadal from my work and am enjoying making what I want for myself. I may even be able to make a buck or two with it.
    Member
    Jan 2019
    74
    If you remove the parenthesis from the op comment (1008) in the post you can output code and comment in your NC file.
    Community Moderator cadcam's Avatar
    Apr 2003
    3521
    Using the comments as stated in the earler posts. you can also use Manual entry as an option.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Adding new tool locations - tool changer M6start VB script editor in mach 3
    By demonx in forum Mach Wizards, Macros, & Addons
    Last Post: 12-23-2016, 06:20 AM
  2. Not able to see tool paths
    By SwampDonkey in forum CamBam
    Last Post: 10-07-2014, 06:47 PM
  3. Tool Library and tool paths.
    By EricMFG in forum CamWorks
    Last Post: 10-28-2013, 06:08 AM
  4. individual tool number counter
    By bigbobr in forum Haas Mills
    Last Post: 02-21-2013, 04:34 PM
  5. 3d tool paths
    By ginamc in forum OneCNC
    Last Post: 03-19-2005, 06:17 PM
