585,605 active members*
3,263 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Partner 1D. Removing X & Y Belts and pulleys.
Results 1 to 6 of 6
    Jan 2010
    78
    I'm going through and cleaning up the machine. Also wanting to remove and replace the X & Y axis belts and pulleys. The old belts I cut off. The X axis motor is mounted on slots with four Allen head screws. Easy enough. The y-axis though, does not seem to want to be adjusted in the same manner. How do I adjust the y-axis motor to install the new belt?
    Also, the pulleys seem to be mounted the same way. But I don't see how they come off, any help here?
    Jan 2010
    78
    Re: Partner 1D. Removing X & Y Belts and pulleys.
    Also, there is red grease on the linear rails. But it looks to be VERY old. What grease should I replace this with?
    Are there grease/oil lube locations on the machine other than the rails?
    I've only done maintenance on manual mills and lathes
    Jan 2010
    78
    For reference:
    X axis and Y axis Pulleys.
    Mar 2017
    63
    To get the big pulley off take out the 2 set screws, and put one in the middle hole and tighten to pull the hub out of the center of the pulley. It's a taper lock.
    Sent from my SM-N960U using Tapatalk
    Jul 2006
    130
    I can't find where i had the maintenance section of the Partner series, but they recommend something along the lines of Mobile XHP 222 I believe.
    Jul 2010
    548
    Hi Sen. The grease you are looking at id probably a variant of the "red and tacky" the Milltronics calls for Mobilith EP grease ( it is a blue / green color) you can find it at most auto parts stores.
    The Y axis motor has no slot adjustments. you will find 2 sets of mounting holes under the motor.
    again give me a call
    sportybob
  1. GT2 belts and pulleys
    By RCaffin in forum Linear and Rotary Motion
    Last Post: 01-13-2017, 01:30 AM
  2. Pulleys and belts, where to buy
    By millbert in forum Benchtop Machines
    Last Post: 06-08-2014, 08:33 AM
  3. belts and pulleys
    By grf in forum Benchtop Machines
    Last Post: 10-30-2010, 11:16 PM
  4. When to use pulleys and belts with steppers
    By Barefootboy4 in forum Servo Motors / Drives
    Last Post: 07-23-2009, 03:23 PM
  5. Belts & pulleys?
    By Splint in forum Australia, New Zealand Club House
    Last Post: 04-15-2005, 10:29 AM
