585,930 active members*
3,984 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Labvolt 5400 5500 5600 update firmware procedure????
Page 1 of 2 12
Results 1 to 20 of 29
    Jul 2017
    348
    hi
    i obtained these older labvolt cnc machines and dont know how to update firmware
    i have the firmware file but getting it onto the machine is a mystery
    no usb
    no LAN
    no floppy
    mine were manuf around 2000
    the festo reps keep telling to use the floppy drive which my machines do not have
    can someone help me?
    Dec 2005
    436
    Re: Labvolt 5400 5500 5600 update firmware procedure????
    Did you iopen up the machine?
    Is there any sort of connector hidden inside?
    Jul 2017
    348
    Yes i have openedmall the machines...nothing inside that i can see as far as floppy drive etc
    Dec 2005
    436
    So how do you load CNC programs ( G code)? There has to be some sort of electronic connection? aside from floppy drives.......electronic connectors like parallel port connectors or DB9 connectors or ISA slots?
    How about posting pictures of the electronics and the cabinet?
    Jul 2017
    348
    Hi cncuser
    thansk anyways but im looking for someone who is familair with these brand machines as they are non typical
    Quote Originally Posted by cncuser1 View Post
    Nov 2009
    4415
    As you will find out there will be a slim chance of interacting with the original motion controller. For a variety of reasons. Pictures of the machine and control boxes if possible always help.
    Sent from my iPhone using Tapatalk Pro
    A lazy man does it twice.
    Jul 2017
    348
    thank you but i am looking for someone who specifically is familair with this exact model cnc machine as it is not typical and is proprietary
    labvolt 5400 5500 or 5600
    thanks
    There are people here making an effort to help you and you are telling them to go away.
    Maybe you should call Labvolt and ask them? It took less than a second to google them and find their website.
    Jul 2017
    348
    i appreciate your help however labvolt will not assist me this has been a multi month project and its been very difficult these are proprietary machines im looking for sonmeone who is familair with this specific machine.. ..if someone has one of these machines and is familair with how to update firmware on older model please let me know thank you
    Jul 2017
    348
    actually company name is festo didactic now..they really dont know anyhting about the older labvolt/ D&M machines..... unfortunately
    I guarantee there's nothing special inside that controller. If you took some pictures and provided some information some of the knowledgeable folk around here could almost certainly help you. As mentioned, given the age of the machine, you might need a modern motion controller to interact with it. The rest of the parts are likely usable.
    Jul 2017
    348
    Thank you but ive done a lot of research already...and getting nowhere
    thats why i posted this
    i need someone that specifically knows the procedure to upgrade firmware on this proprietary machine
    nothing more nothing less
    this machine has a propreietary pc104 board inside with no visible way to upgrade firmware...some research refers to internal floppy drive
    mine has no floppybdrive
    labvolt does not know how either
    most people that have these machines replaced the proprietary main board with mach3 bob
    this requires extensive work and its not,what i want to do at this point
    these are very well made machines butbthey use very light duty components because they werecdesigned for training purpose only
    they have smaller nema23 270oz steppers....and very low amp chopper drives 2A
    they ghave very nice power supply
    here is a photo
    so if anyone knows how to upgrade the firmware please respond
    thank you
    Jul 2017
    348
    Here is,pic of the labvolt 5600
    Quote Originally Posted by Shelby5041 View Post
    here is a photo
    thank you
    Jul 2017
    348
    The 5400"actually is much more light duty..sherline based
    has tiny nema.23 140oz stepper motors
    actually here isa photo of the chopper drive....anyone know how to,change the amp output? Labvolt sidnt know how to do
    and i attached pic of pc104 main controller board
    Sep 2008
    140
    Looks like a floppy connector and cable in the upper left of the
    center photo.
    Jul 2017
    348
    Negative..that cable is for the lcd front panel control board
    Jul 2017
    348
    These machines can be operated manually via front panel but cant be programmed...just turn spindle on and move xyz axis...so inguess i could use them manually worse case scenerio
    May 2008
    84
    Did you read the readmeE.txt file include with the downloaded ZIP file?
    Detailed instructions therein.
    Jul 2017
    348
    Yes
    my machine is older manuf 2000
    does not have floppy does not have ethernet
    Quote Originally Posted by AR1911 View Post
    May 2008
    84
    There are USB to Ethernet and possibly USB to Parallel pot convertors. I don't know if they would work in this application, but they are cheap.
    But I think you are SOL. There is a reason everyone converts these to Mach or LinuxCNC. With all the time and research you have spent thus far you could have had a working machine today.
    That is what I did with my 5400 once I determined the OE setup was unworkable. I sold the components for (almost) enough to buy what I needed and moved on.
Page 1 of 2 12
